CPPM serial number
  • 1.  CPPM serial number
    Posted Jun 19, 2014 07:39 AM
    How do I identify a particular instance of CPPM VM as I need to transfer some licenses. The subscription ID is the same for all devices in the cluster.
  • 2.  RE: CPPM serial number
    Posted Jun 19, 2014 07:41 AM
    Log in to the appropriate server and click the version number at the bottom right.
  • 3.  RE: CPPM serial number
    Posted Jun 19, 2014 07:43 AM
    It says serial number : None
    Could this be because its a VM?
  • 4.  RE: CPPM serial number
    Posted Jun 19, 2014 07:54 AM
    If you have the email with the certificate IDs it should right under it
  • 5.  RE: CPPM serial number
    Posted Jun 19, 2014 07:57 AM
    Right, I have this info, but I need to know how this links to the individual VM instance as they were all purchased at the same time.
  • 6.  RE: CPPM serial number
    Posted Jun 19, 2014 08:35 AM
    SSH into the box and run "show license", then correlate the Product Key with the certificate/serial number in your licensing account.
  • 7.  RE: CPPM serial number
    Posted Jun 19, 2014 10:33 AM
    Thanks for the help - I have managed to identify two devices, however the other two were re-installs with new licenses generated so I do not have a correlation to a serial number. I guess I will just have to get TAC involved to sort this out. Finding a serial number - surely there should be a simpler way of doing this sort of thing!!!!!
  • 8.  RE: CPPM serial number
    Posted Jun 19, 2014 10:34 AM
    TAC should be able to figure it out with the server's license key.
  • 9.  RE: CPPM serial number
    Posted Jun 19, 2014 10:36 PM
    IF you look at the licensing.arubanetworks.com you can match the license key >certification ID>serial number
  • 10.  RE: CPPM serial number
    Posted Sep 20, 2018 05:00 PM
    so there's not a command to find the serial number in the CLI?
