CPPM Server Replacement
  • 1.  CPPM Server Replacement
    Posted Feb 16, 2019 07:18 PM
    Good evening Team,
    One of our customers has aRunning C2000 CPPM in production which seems tohave hardware issue , Alreday worked with tac tea and a new hardware has arrived,
    I just want to mkae sure and verify my plan below
    1- Initial configuration for the new CPPM with same IP , Hostname  , after disconnecting the old one
    2- Importing certificates from the old one to the ne one ( Radius , HTTPS )
    3 - Joining the domain
    4- Restotre backed up cpnfiguration from the old server
    Another question about the licnesin :
    When Initializing the new CPPM server , Platform Activation key will be found on customer MY HPE networking ??!!
    Other Liceneses will be transferred through MY HPE networking ??
    Thanks In Advance
  • 2.  RE: CPPM Server Replacement
    MVP EXPERT
    Posted Feb 17, 2019 05:13 AM
    For the licenses your best work together with TAC support.
    Is this just one node or a clearpass cluster? In a cluster the fimware must be the same and work with publisher <> subscriper database sync instead of put back a raw DB backup.
    You can export your certificates pcks12 and ca-chain certs from your old node before start.
    Furher your plan seems like fine to me.
  • 3.  RE: CPPM Server Replacement
    Posted Feb 18, 2019 03:39 AM
    Thank you Sir For yur reply
    It is only one node
    I will follow te advice and align ith tac team to work on ths together.
    Thank you
