Hey,
I was wondering if there is a safe way to 'replace' the default '[Policy Manager Admin Network Login Service]' with a service that would authenticate domain accounts instead of local accounts.
This service can't be edited and I am hesitant to move this service from it's default location (1) for fear that I will end up locking myself out of the CPPM while I test.
I would like to use an LDAP group for admins that can login '/tips'. Currently it is setup for local accounts only.
I was thinking of using the same method used to do the "Guest Operator Logins" service.
My only fear though is the definition of the service. The only thing that filters the '[Policy Manger...]' service is the 'NAD-IP-ADDRESS'. I suspect I would have to put my custom service before the default service to do testing, but if I get the definition of the service wrong I could end up locking myself out of the CPPM. I think anyway...
Does anyone have some recommendations I could try to set this up? Or is it not recommended?
Thank you,
Cheers
