CPPM upgrade from 6.4 to 6.5
  • 1.  CPPM upgrade from 6.4 to 6.5
    Posted Apr 14, 2015 05:44 AM
    Hi Guys
    I have been tasked with upgrading customer CPPM nodes (HW-500) 6.4 to 6.5 with 5 updates to perform first
    Existing Publisher/Subscriber cluster configuration: -
    1) Publisher IP x.x.x.24, Subscriber IP x.x.x.25
    2) No ViP configured
    3) Publisher failover not enabled
    4) 802.1x Radius requests forwarded from WLC - profile contains entry for both CPPM nodes .24 and .25
    Q - From above config, following a Publisher reload eg after update patch install, will the Subscriber automatically become Publisher?
    I have read posts stating the Subscriber becomes 'Out of Sync' and is then in a position to have the same patch installed??
    Q - with Publisher failover not enabled, will the Subscriber ever become Publisher dynamically? If not is the Subscriber there until manually told to become Publisher??
    Many thanks in advance
  • 2.  RE: CPPM upgrade from 6.4 to 6.5
    Posted Apr 14, 2015 07:35 AM
    No , you need publisher failover enabled in order to have this functionality.
    Both need to have the same level code to be insync
  • 3.  RE: CPPM upgrade from 6.4 to 6.5
    Posted Apr 15, 2015 11:24 AM
    Many thanks Victor
    Gary Shaw
    NOC - Lead Network Support Engineer
    Networks & Telecoms - Connectivity
    FUJITSU
    IRE11, Trident House, 301 Airport Road West, Belfast, BT3 9AE
    Tel: +44 (0) 8433549290 Internal: 7444 9290
    Mob: +44 (0) 7867830051
    Fax: +44 (0) 2890 734040
    E-mail: gary.2.shaw@uk.fujitsu.com
    Web: http://uk.fujitsu.com/
    [cid:image001.png@01D07798.7116D340]
    [cid:image002.png@01D07798.7116D340]
    [cid:image003.png@01D07798.7116D340]
    [cid:image004.png@01D07798.7116D340]
    Fujitsu is proud to partner with Shelter, the housing and homeless charity
    Reshaping ICT, Reshaping Business in partnership with FT.com
    P Please consider the environment - do you really need to print this email?
    Unless otherwise stated, this email has been sent from Fujitsu Services Limited, from Fujitsu (FTS) Limited, or from Fujitsu Telecommunications Europe Limited, together "Fujitsu".
    This email is only for the use of its intended recipient. Its contents are subject to a duty of confidence and may be privileged. Fujitsu does not guarantee that this email has not been intercepted and amended or that it is virus-free.
    Fujitsu Services Limited, registered in England No 96056, registered office 22 Baker Street, London W1U 3BW.
    Fujitsu (FTS) Limited, registered in England No 03808613, registered office 22 Baker Street, London W1U 3BW.
    PFU Imaging Solutions Europe Limited, registered in England No 1578652, registered office Hayes Park Central, Hayes End Road, Hayes, Middlesex, UB4 8FE.
    Fujitsu Telecommunications Europe Limited, registered in England No 2548187, registered office Solihull Parkway, Birmingham Business Park, Birmingham, B37 7YU.
  • 4.  RE: CPPM upgrade from 6.4 to 6.5
    Posted Apr 15, 2015 12:40 PM
    Gary,
    I wanted to quickly ask about "I have been tasked with upgrading customer CPPM nodes (HW-500) 6.4 to 6.5 with 5 updates to perform first"  the 5-updates....
    You can go straight from any 6.4.x release to 6.5.0, you don't need to apply intermediate updates.
  • 5.  RE: CPPM upgrade from 6.4 to 6.5
    Posted Apr 15, 2015 01:31 PM
    Hi Danny - thanks for that. The release notes advise applying all patches first, can you confirm where it states otherwise?
    Regards
    Gary Shaw
    FUJITSU
    [cid:image001.png@01D077AA.32FF1D30]
    [cid:image002.png@01D077AA.32FF1D30]
    [cid:image003.png@01D077AA.32FF1D30]
    [cid:image004.png@01D077AA.32FF1D30]
  • 6.  RE: CPPM upgrade from 6.4 to 6.5
    Posted Apr 15, 2015 02:14 PM
    Gary,
    Page15 of the Upgrade Release Notes.... note that 90% of our users updated through the GUI.... let me know if you want to chat and I'll call you.
    For 6.4.x upgrades through the Software Updates portal in the Policy Manager user interface, or through
    the Web service, upgrade is supported for any 6.4.x version.
    For 6.4.x upgrades through the CLI, there are two options:
    If you are on 6.4.2 or later, you can upgrade directly to 6.5 through the CLI.
    If you are on 6.4.0 or 6.4.1, you must first download and install the 6.4.0 CLI updates patch. At
    support.arubanetworks.com, go to Download Software > ClearPass > Policy Manager > Current
    Release  and select CPPM-x86_64-20140919-cli-der-support-patch . After you have installed the
    patch, update to 6.4.2 or higher. You can then upgrade to 6.5 through the CLI.
