CPPM upgrade from 6.4 to 6.6
  • 1.  CPPM upgrade from 6.4 to 6.6
    Posted Oct 31, 2017 10:36 AM
    I can see this on the release note
    i was recommended by the tac to just create a new vm backup the old 6.4 and upload the backup to the new 6.6 machine
    Now the problem is taht with the new VM i woudl need 1TB because its 6.6
    The client seems it cannot give me 1TB
    And on the release note it says that if you upgrade from 6.4 you can use the 500GB it already has or at least its how i understand.
    It is possible to use the same 500gb hard drive to go to 6.6?
    Cheers
    Carlos
  • 2.  RE: CPPM upgrade from 6.4 to 6.6
    Posted Oct 31, 2017 11:01 AM
    Yes
  • 3.  RE: CPPM upgrade from 6.4 to 6.6
    Posted Oct 31, 2017 11:24 AM
    it is no recommeneded? i ask becase tac adviced me to do a new VM.
    I would like to know what is recommeneded
  • 4.  RE: CPPM upgrade from 6.4 to 6.6
    Posted Oct 31, 2017 11:27 AM
    You should really follow TAC's guidance.
  • 5.  RE: CPPM upgrade from 6.4 to 6.6
    Posted Oct 31, 2017 11:43 AM
    Ill just ask again... they closed that ticket a while ago.   And the client doesnt seems to have the 1TB space available for it.
    Cheers
    Carlos
