I wanted to break this out of the other thread to make it easier to find in a search.
Big thanks to Danny for this post....
Hello.....
Before you drop ANY disk you need to ensure this is the INACTIVE disk your using……VERY IMPORTANT
Its not always going to be the case that 6.1 is on SCSI 0:1 or 6.2 is on SCSI 0:2. It could be the other way round thats why before you remove any disk be sure your removing the correct disk.
Make the new disk TWICE the size of the old disk as we will partition this disk into two logical volumes which we will use going forward after 6.3.0...... don't just make the existing disk larger.....do a remove and then an add.
Note: Never remove SCSI 0:0.
Figuring out which disk is active v inactive, the best way is to use the vSphere/vCenter tools...in vSphere.....
Go to the monitoring page and click on performance. There will be a drop-down list on the RHS of the screen....'Switch to:' Select virtual disk......if you only see a single disk....go to chart options and ensure all disk are selected under 'Objects'.......
You should see either disk one (scsi 0:1) or two (scsi 0:2) with activity. The one that does not have any activity can be deleted and then re-added, ensure you double the size of this disk from its previous size.
Hope this helps.
Danny
