Hi All,
Just wanted to check if it is possible to have feed from Facebook, Instagram, twitter that is constantly updating on a guest login page on Clearpass?
If so, how can this be setup?
Any HTML snipper those providers give you will work. The only hiccup is knowing what hostnames to whitelist in the captive portal profile.
Thanks for the confirmation this is achieveable.
Any idea on where to start to start the setup?
There is some info in this pinned thread that may get you on the right track. It has a section for adding weather information to the guest page. Not exactly the same, but the same concept.
Here you go.
Thanks will have a look into it further.
You start with whoever is providing your feed. They will have exmaples of HTML to drop in place, no different than advertising folks. Your only CPPM-related piece is whitelisting all the domains the code may need, but that is a TODO on the controller/AP.
