CPPM%3A How to monitor and record%3B the cpu and bandwidth
  • 1.  CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 05, 2014 12:19 PM
    -- We wanted to monitor and record the information on “system monitor” as a report or graph format.
    -- Monitoring > Live monitoring > System Monitor,  shows the statistics including CPU, memory, physical disk space and swamp disk space.
    -- is there a way to save that information in any format (generating it as report or in graph format)?
    -- We want to compare those current statistics with old ones.
    Thank you in advance.
  • 2.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 05, 2014 12:29 PM
    There are two ways.
    1. You can use airwave.
    In 6.3 CPPM uses Graphite to collect the stats for its metrics. You can access it by going to https://CPPM_address/graphite. I don't believe it has a built in reporting but there are some third party apps that work with it.
  • 3.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 05, 2014 02:42 PM
    thank you for your answer:
    I have a another query,
    Do we have an option to get the output as a report on insight (or in CPPM itself ) on a excell or graph format?
    Or the only way would be to use any external monitoring tool to get the outputs?
  • 4.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 05, 2014 02:46 PM
    Nothing natively. You would need to use Airwave or another tool
  • 5.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 05, 2014 04:03 PM
    Do we have any document or aruba KB which explain the procedure to monitor those statistics with CPPM.
    Thank you for your help.
  • 6.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 05, 2014 04:31 PM
    The Graphite functioanlity Troy poited you to is a brand new feature in the latest 6.3.0 code release. I refer to it as sunrise release in that we have included the core functionality but we will develop additional use-cases and reports in future releases.
    I do have plans to release an intro to Graphite in a TechNote. This should be one of the doc that can be shared past our internal SE/Support.
    I will post back here when I have a verion in a state I can share with you all, or you can ping your local Aruba SE for a copy. Expect it to be in 10-14 days time. It will only be a short overview.
  • 7.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 26, 2014 10:18 PM
    I cant find a way to restrict access to Graphite. Guest users are able to view this information with the appropriate URL and no authentication.
    This is a security concern for my customer. Is Aruba working toward implenting some form of access control to this service?
    Chris
  • 8.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 26, 2014 10:20 PM
    Yes
  • 9.  RE: CPPM%3A How to monitor and record%3B the cpu and bandwidth
    Posted Feb 26, 2014 10:22 PM
    I am logging a TAC case for this, but in the mean time can you provide any sort of official response on timeframes for implementation?
    Cheers
    Chris
