CPSec and master/local controllers
  • 1.  CPSec and master/local controllers
    Posted Apr 26, 2017 03:30 PM
    Hi guys,
    I would like to clear a doubt about CPSec and master and local controllers.
    When CPSec is enabled, master and local controllers exchange clear and unencrypted information over IPSec tunnels. This is the default.
    When CPSec is disabled, master and local controllers exchange clear and unencrypted information.
    Am I right?
    Julián
  • 2.  RE: CPSec and master/local controllers
    Posted Apr 26, 2017 03:47 PM
  • 3.  RE: CPSec and master/local controllers
  • 4.  RE: CPSec and master/local controllers
    Posted Apr 27, 2017 10:38 AM
    Hi guys,
    Any idea?
    Julián
  • 5.  RE: CPSec and master/local controllers
  • 6.  RE: CPSec and master/local controllers
    Posted Apr 27, 2017 11:30 AM
    Hi Victor,
    Thank you, you are right, I was confused. Then another question.
    In an Aruba document I have found that in a master/local arquitecture IPSec tunnels are automatically created between the master and each local for inter-controller communication, but it also explains the commands to use to setup the IPSec tunnel.
    Then, in a master/local arquitecture, do these IPSec tunnels automatically created or do they have to be manualy created?
    Julián
  • 7.  RE: CPSec and master/local controllers
    Posted Apr 27, 2017 04:05 PM
    It is a manual process :
    https://youtu.be/bE3tst09-RM
    Get Outlook for iOS
  • 8.  RE: CPSec and master/local controllers
    Posted Apr 27, 2017 04:22 PM
    Hi Víctor,
    Everything clear :)
    Thanks for you interest.
    Best regards,
    Julián
