crash of controler & WIFI every X days when memory is too high
  • 1.  crash of controler & WIFI every X days when memory is too high
    Posted Nov 27, 2011 02:12 PM
    We have WIFI interruption regularly (every X days). Each time we notice the same behavior:
    -Memory utilization reaches value of 210MB /250MB
    -Each time interruption lasts 5mn and standby controler doesn’t activate
    -Always same messages appear in the errore.log :
    <date>   syslog: LargeReplyTimeout: TIMEOUT
    <date>  syslog: PAPI_SendWaitForLargeReply: No response from 7f000001:8214
    At the same time, we notice there is a purge of files during the interruption :
    memory snapshot: before interruption
    Memory (Kb): total: 256060, free: 42671
    … Querying excessively large apps
    auth     : 25/20M (cur/typical)  5M over
    Large files under /tmp :
    /tmp:-rw-------    1 root     root     29802496  core.17057.auth.xxx_28161
    memory snapshot: after interruption :
    Memory (Kb): total: 256060, free: 64579
    auth     :  4/20M (cur/typical)  0M over
    Does somebody have seen this behavior before ?
    Last point : in the technical logs, the user table is limited to 94 users
    >> show aaa state configuration    / Current/Max/Total Users     94/94/94
    The controller is supposed to accept up to 2048 users, so why can’t I have more than 94 users authenticated at the same time ?
  • 2.  RE: crash of controler & WIFI every X days when memory is too high
    Posted Nov 27, 2011 02:23 PM
    That Max is the max you have it at a single time, not the max you can hit.
  • 3.  RE: crash of controler & WIFI every X days when memory is too high
    Posted Nov 27, 2011 02:32 PM
    Which AOS version are you running?
  • 4.  RE: crash of controler & WIFI every X days when memory is too high
    Posted Nov 27, 2011 08:05 PM
    Questions:
    - What controller model?
    - What version of code?
  • 5.  RE: crash of controler & WIFI every X days when memory is too high
    Posted Nov 28, 2011 04:37 PM
    The controler is OAW-6000 release 3.4.4.3
    I use supervisor card I => I can't upgrade to rel 6
    Zjennings, what do you mean "That Max is the max you have it at a single time" ?
    I can't have more than 94 users every seconde ? every 100msec, 5mn ?
    thanks
  • 6.  RE: crash of controler & WIFI every X days when memory is too high
    Posted Nov 28, 2011 04:51 PM
    thanks
    It is the Max users that have been connected at a single time. The "it" was a typo. It should have said "That Max is the max you have seen at a single time." It might be cleared on reboot (aka start back at 0). It is definitely NOT a limit.
