create a cluster Mobility Controllers in Mobility Master?
  • 1.  create a cluster Mobility Controllers in Mobility Master?
    Posted Apr 17, 2018 11:43 PM
    i try to create the environment that uses one mobility master that manage two mobility controllers. Then try to create one folder for two mobility controllers in purpose can push the configuration to both controllers exclude IP and interface configuration.
    anyone can help to explain how to push the configuration on folder to both of mobility controller or at least i can do sync the configuration between mobility controller? or any other method to create a cluster mobility controller with active-active mode and push same configuration on one cluster in mobility master?
  • 2.  RE: create a cluster Mobility Controllers in Mobility Master?
    Posted Apr 18, 2018 03:12 AM
    Have you seen "ARUBA 8.X ARCHITECTURE OVERVIEW & UI NAVIGATION" on the page here?:  https://community.arubanetworks.com/t5/Training-Certification-Career/EMEA-Airheads-On-Demand-Tech-Webinars/td-p/271911
    There is alot of detail that needs to be understood, so there is no real shortcut or quickstart.  Please also take a look at the other 8.x webinars on the page when you get a chance, also.
  • 3.  RE: create a cluster Mobility Controllers in Mobility Master?
    Posted May 13, 2018 10:51 PM
    wow, great article joseph
    thank youu
