Wired Intelligent Edge
Create a testing environment
  • 1.  Create a testing environment
    Posted May 26, 2017 06:39 AM
    Hi all,
    I posted previously and got a really helpful answer in moving my  "router on a stick" to using the HP Aruba Switch for routing. The customer wishes to proceed with this and so I'd like to get everything working in a software lab first.
    Hardware: HP Switch 5412zl (J8698A)
    Version: K.15.17.0012, ROM K.15.30
    The other switches can be generic as they are only going to operate on L2.
    Can I download a simulator of this switch for testing? I've installed HCL onto a test environment but can't find where to download specific devices. Any help would be massively appreciated.
    Phil
  • 2.  RE: Create a testing environment
    Posted May 28, 2017 05:32 PM
    Hi Phil, The 5412 or similar switches don't have simulator support. HCL is is for all Comware based switches. Hope this helps!!!
  • 3.  RE: Create a testing environment
    Posted May 28, 2017 05:47 PM
    Thanks Dobias,
    It certainly helps in that I can't pre-test my setup. Any ideas what I might be able to do rather than just implement the changes to a production environment?
  • 4.  RE: Create a testing environment
    Posted May 29, 2017 03:07 AM
    Do you have contacts with an Aruba SE? They can probably get you some temporary switches.
