Create Certificate Manually in CP Onboard
  • 1.  Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:03 PM
    Is it possible to manually create and export a client certificate?  I have several iOS8 devices that need to get on the network, but onboarding is not working.  I'd like to manually issue certs as a workaround.
  • 2.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:06 PM
    During the onboard process it gives you the option to manually download and install it.
  • 3.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:11 PM
    Is it not possible to create certificates manually via the admin GUI?  My iOS8 devices can't get past the captive portal that sits before the onboarding login.
  • 4.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:15 PM
    You can sign server authentication CSRs but I don't think you can manually issue a client cert. Why not just use PEAP for those devices?
  • 5.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:19 PM
    Yes you can manually do it. Go to onboard--management we cert request
  • 6.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:20 PM
    Stupid spell check. :)
    New certificate request
  • 7.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:24 PM
    What he said ^^^
  • 8.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:30 PM
    Generate a new certificate signing request?
  • 9.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:34 PM
    Yes
  • 10.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 04:36 PM
    Perfect.  Thank you.
  • 11.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 06:26 PM
  • 12.  RE: Create Certificate Manually in CP Onboard
    Posted Aug 01, 2014 07:43 PM
    Awesome! Thanks for the link.
  • 13.  RE: Create Certificate Manually in CP Onboard
    Darn.
    I wanted to keep everything uniform - EAP TLS for all iOS devices.  Also, I can be sure that only one device per user is on the network when enforcing onboarding/certs.  Not sure if that's possible with PEAP.
    Thanks for the feedback, Tim.
