create two SSID's
  • 1.  create two SSID's
    Posted Mar 07, 2018 08:41 AM
    hi all ,
    i have some questions regarding ClearPass:
    1- i create one SSID with guest authentication with MAC caching and all thing working fine but how i can set the session time expired for the guests
    note : this SSID work with self guest registration page .
    2- i want to create another SSID for VIP but with web login what i should configure in controller and ClearPass , i don't think we will do all thing from beginning as per first SSID.
    3- how i can install the certificate to make all users using Google chrome to redircting without warning screen .
  • 2.  RE: create two SSID's
    Posted Mar 11, 2018 01:48 AM
    please help .
  • 3.  RE: create two SSID's
    MVP EXPERT
    Posted Mar 11, 2018 05:39 AM
    Hey,
    1) What is doing the enforcement for the SSID, is this ClearPass? If so have you will need to adjust the Session Length Enforcement Profile you have configured.
    http://www.arubanetworks.com/techdocs/ClearPass/6.6/PolicyManager/Content/CPPM_UserGuide/Enforce/EPSession_Restrictions.htm
    2) Take a look at the below. Configure a Web Login page as opposed to the Self Registration part.
    3) What Operating System is this? There is various methods of distributing a certificate to a client depending on the OS you are running. For example you could install a cert via GPO.
  • 4.  RE: create two SSID's
    Posted Mar 11, 2018 09:58 AM
    thank very much for your help .
    another small question if want create new field but in this field i want alphabet only without numbers and special character how to make this .
  • 5.  RE: create two SSID's
    MVP EXPERT
    Posted Mar 11, 2018 10:21 AM
  • 6.  RE: create two SSID's
    Posted Mar 12, 2018 03:35 AM
    from this document i cant find the solution there's no role to set all thing in field alphabet only
  • 7.  RE: create two SSID's
    Posted Mar 13, 2018 08:26 AM
    No answer ?
