Creating a CSR with multiple SAN options
This thread has been viewed 56 times
  • 1.  Creating a CSR with multiple SAN options
    Posted Aug 21, 2013 11:44 AM
    All,
    Is it possible to put multiple entries into the SAN field when generating a CSR? I tried entering "DNS:clearpass1.mydomain.org, IP:10.20.100.170" and it threw an error. I'm not sure what the delimiter is between the various SAN entries.
    I'm trying to create a CSR for a VIP that references the publisher and subscriber IPs and FQDNs. I've been told this is the best way to handle certs in CPPM in case of a failover and / or the promotion / demotion of Publishers and Subscribers.
    Eventually, all of us will have dumped so many questions in this forum that it's going to be a great wiki! Also, it keeps cjoseph on his toes!
    Thanks!
    -Mike
  • 2.  RE: Creating a CSR with multiple SAN options
    Posted Aug 21, 2013 11:55 AM
    I believe there is no spaces.
    DNS:cplab.clearpassdemo.com,IP:10.80.2.200
  • 3.  RE: Creating a CSR with multiple SAN options
    Posted Aug 21, 2013 01:15 PM
    Troy,
    Worked like a charm - thanks!
    -Mike
  • 4.  RE: Creating a CSR with multiple SAN options
    Posted Aug 21, 2013 11:24 PM
    @boston1630 wrote:
    .... I've been told this is the best way to handle certs in CPPM in case of a failover and / or the promotion / demotion of Publishers and Subscribers....
    I'm curious if you have more information that you (or someone else) can share on why this was recommended.  Is it just a recommended practice or is there a real technical explanation behind it?  Thanks.....
  • 5.  RE: Creating a CSR with multiple SAN options
    Posted Aug 22, 2013 12:35 AM
    Hi clembo,
    I have been told by the local SE and the local CPPM engineer that this is recommended for SSL connections to the Virtual IP service in a Publisher / Subscriber setup.
    I've had a customer set it up on their own - I'm going to be rocking it out at a different customer site next week. I'll let you know how it goes.
    -Mike
  • 6.  RE: Creating a CSR with multiple SAN options
    Posted Aug 26, 2013 12:52 AM
  • 7.  RE: Creating a CSR with multiple SAN options
    Posted Oct 17, 2022 01:55 PM
    Hi All,
    Bringing up an old post here...
    If at SAN field I use FQDN only, does the Subscriber need to be able to resolve the FQDN of the Publisher (to be able to form cluster aka Make Subscriber) ?
    For example I use "DNS:cp-pub1.abc.com"
    And:
    - does the hostname need to be the same as the FQDN at SAN field ?
    - does the CN need to be the same as the FQDN at SAN field ?
  • 8.  RE: Creating a CSR with multiple SAN options
    Posted Oct 17, 2022 11:01 PM
    Just as old as this post is the certificates 101 document here:  https://support.hpe.com/hpesc/public/docDisplay?docId=a00100345en_us
    Why you would make a SAN field is to ensure that a Captive Portal User will not get an error no matter what ClearPass Box answers the https request.  The publisher and subscriber have nothing to do with SANs.
