last person joined: 11 hours ago
creating accounts with expire_after 24h
  • 1.  creating accounts with expire_after 24h
    MVP
    Posted May 29, 2013 01:15 PM
    It appears this should be relatively simple to do but I can't seem to get the thing working as I want it.
    The operator must be able to set the date/time the account starts but may not change the account expiry time. This needs to expire 24 after after the account is activated (not created).
    To accomplish this I tried creating custom form fields in the operator profile and then change modify_expire_time and expire_after fields.
    The guest manual mentions:
    - If modify_expire_time is “expire_after” or “expire_time”, then the expiration time is determined
    according to the expire_after or expire_time fields as explained below.
    -> how exactly? set a string value? change the options generarot or its parameters?
    - If expire_after is set and not zero and the account will be activated immediately, then add the value
    in hours to the current time to determine the expiration time.
    - If expire_after is set and not zero and account activation is set for a future time (schedule_time)
    instead of the current time, then the expiration time is calculated relative to the activation time
    instead of the current time.
    - Otherwise, if expire_after is zero, negative or unset, and expire_time has been specified, use that
    expiration time. If the expire_time specified is in the past, set do_expire to 0 and ignore the
    specified expiration time.
    - Otherwise, if expire_time is not specified, then the expire_time is not set and do_expire will
    always be set to zero.
    So I tried pretty much any combination of the "modify_expire_time" and "expire_after" form Fields but I cannot get it to work as intended. It keeps complaining: "The expiration time occurs prior to the activation time."
    Anyone that can lend a hand with this?
  • 2.  RE: creating accounts with expire_after 24h
  • 3.  RE: creating accounts with expire_after 24h
    Posted May 29, 2013 02:30 PM
    Hi Koen
    First, if you want to limit this for operators you need to create a new form and limit access to this for the said operators.
    You will get some answers in the links from kdisc98, but it won't get you all the way.
    • Go to Configuration -> Forms & Views, select the create-user form.
    • Click Duplicate and edit this to a new name (ie. create-user-24h)
    • Click "Use" to open the form in a new tab to check out which fields you will want to edit.
    • Go back to the create-user-24h form -> click Edit fields
    Changes to create-user-24h form
    • sponsor_name -> might want to change this to a read only field with type "static text"
    • modify_expire_time -> disable this
    • expire_time -> disable this
    • expire_after -> change to type static text and initial value to 24
    • do_expire -> might want to change this to hidden and initial value of 1, 2, 3 or 4 depending on what you want to happen at expiration. I normally use 2 - disable and logout
    Then go to Administration -> Operator Logins -> Profiles
    • Create a new Profile (or edit your existing) and modify the limitations you want to apply
    • Change Guest Manager settings to Custom, and just leave the form edited above as their only create user form.
  • 4.  RE: creating accounts with expire_after 24h
    MVP
    Posted Jun 12, 2013 05:37 AM
    When you put it like I don't understand why I had issues figureing it out :)
    Confirmed working and exactly what I needed so kudos and thanks!
