Creating an additional SSID, Aruba 620
  • 1.  Creating an additional SSID, Aruba 620
    Posted Aug 17, 2012 05:45 PM
    I am under the impression that my AP's are capable of broadcasting more than one WLAN. When I try to set one up with the WLAN wizard however, I get all the settings in, and it says it is pushing the configuration to the controller for a short second, but nothing changes.
    A little background;
    Its a Dell branded 620
    I am accessing the configuraiton setup via HTML
    I have one WPA2 wireless network running with Radius Auth on the Default and only Vlan- Vlan1
    I would Like another WPA2-PSK network, possibly hidden, for items that stay inside the network permanently, and require AD server access for Logon Authentication.
    I tried creating it on the same Vlan, because the size of my network doesn't warrant segmenting, / I'm not sure how to go about managing one.
    So, any thoughts?
    I suppose I can always reset the controller and start from scratch, but I figured the Wizard should work just fine if my configurations are correct.
    We have 5 AP105s broadcasting.
    Thanks!
    Dave
  • 2.  RE: Creating an additional SSID, Aruba 620
    Posted Aug 17, 2012 05:56 PM
    So, any thoughts?
    Thanks!
    Dave
    Please clear your browser cache or try another browser.  What version of Dell Code is this?
  • 3.  RE: Creating an additional SSID, Aruba 620
    Posted Aug 17, 2012 06:05 PM
    I have been using Firefox, this is the OS info, I am going to try it out in IE.
  • 4.  RE: Creating an additional SSID, Aruba 620
    Posted Aug 17, 2012 06:15 PM
    Worked Perfectly in IE, Thats peculiar. It wasn't taking me through the AAA portion of the Wlan setup in Firefox...
    Thanks for the Solution!
  • 5.  RE: Creating an additional SSID, Aruba 620
    Posted Aug 17, 2012 07:21 PM
    Just to let you know there is a bug with mozilla 14 and the wizard
    https://community.arubanetworks.com/t5/Campus-WLAN-and-High-Density-Wi/Mozilla-14-possible-bug-with-Aruba-Wizard/td-p/41118
    Aruba is aware of that
