Creating device in ClearPass Guest triggering WebAuth
  • 1.  Creating device in ClearPass Guest triggering WebAuth
    Posted Aug 01, 2017 10:36 PM
    Every time I create a device, it will trigger a WebAuth in ClearPass. Anyone has the same issue? Or it's as per design? It's a bit annoying when the 'reject' record showing in the Access Tracker.
    Thanks.
  • 2.  RE: Creating device in ClearPass Guest triggering WebAuth
    Posted Aug 01, 2017 10:51 PM
    It is by design. It allows you to trigger a Disconnect Message or Change of Authorization in case the user connected the device before registering it and therefore is stuck in a captive portal role.
    You can also use it to update external systems via the ClearPass Exchange framework.
  • 3.  RE: Creating device in ClearPass Guest triggering WebAuth
    Posted Aug 01, 2017 10:54 PM
    Thank you Tim! It's really helpful.
    BTW, do you know how to limit the device number an Operator can create?
  • 4.  RE: Creating device in ClearPass Guest triggering WebAuth
    Posted Aug 01, 2017 11:00 PM
    You can set the account limit in the operator profile.
    Please note that this is total for both guest user accounts and device registrations. (Limit of 10 = 7 guest users, 3 devices || 5 guest users, 5 devices, etc).
  • 5.  RE: Creating device in ClearPass Guest triggering WebAuth
    Posted Aug 01, 2017 11:04 PM
    Great. Thanks!
