Is it possible to create multiple PTP links on one Radio of Outdoor AP-175 using directional antennas? If yes, what is the impact of this design on the performance of the access point.
this is not possible with AP-175. Each radio in on a separate band, and only one radio can be meshed.
MeshOS does support this, using separate channels on each radio to avoid any performance penalty.
I do not understand. Cant we create two PTP links on the same channel in different directions using directional antennas?
No. The radios in AP-175 cannot be on the same frequency band. One is fixed to 2.4GHz and the other to 5GHz.
If you need to go 2 different directions then you must use an omni antenna, which will reduce your overall range.
