Custom Internal Captive Portal
  • 1.  Custom Internal Captive Portal
    Posted Jan 10, 2013 04:35 AM
    Hi.
    Is it possible to customize the internal Captive Portal splash page any more than with the editor on the virtual controller?
    I would really like to be able to edit html/css for the page to customize it.
    Thanks! :)
  • 2.  RE: Custom Internal Captive Portal
    Posted Jan 10, 2013 10:32 AM
    Customization of the  Instant Captive portal page is limited to changing the background colors and text in the boxes.  For more advanced captive portal pages you could add ClearPass Guest to the solution and CP Guest provides a highly customizable page with a lot of advanced guest management features such as guest self-registration, sponsor approvals, reporting, etc.
