custom mgmt-user role
  • 1.  custom mgmt-user role
    Posted Dec 16, 2015 01:22 AM
    Hi Guys,
    is it possible to create custom role for mgmt-user? just like clearpass' role
    my customer request a role to access monitoring tab and ap provisioning only.
    Ricky
    ACMP, CWNA
  • 2.  RE: custom mgmt-user role
    Posted Dec 16, 2015 01:28 AM
    Not with that granularity, the admin roles are:
    Role assigned to the user. Predefined roles include:
    * guest-provisioning: Allows the user to create guest accounts on a special WebUI page.
    * location-api-mgmt: Permits access to location API information. You can log into the CLI; however, you cannot use any CLI commands.
    * network-operations: Permits access to Monitoring, Reports, and Events pages in the WebUI. You can log into the CLI; however, you can only use a subset of CLI commands to monitor the controller.
    * read-only: Permits access to CLI show commands or WebUI monitoring pages only.
    * root: Permits access to all management functions on the controller.
  • 3.  RE: custom mgmt-user role
    Posted Dec 16, 2015 03:06 AM
    Jerrod,
    thanks for your prompt reply.
    so, only default role can be used?
    there is no way for user with no configure rights to access "AP Installation tab"?
    Ricky
  • 4.  RE: custom mgmt-user role
    Posted Dec 16, 2015 06:38 AM
    rickylee,
    There is no way to do it outside of the categories that jhoward detailed above.
