Custom Skin Help - Clearpass Guest Self Registration
  • 1.  Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 08:46 AM
    Would anyone be willing to give me some help on how I can center the main form of the guest self registration page? I have centered my logo and text but having trouble centering the form itself. Thank you.
  • 2.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 09:17 AM
    The <center> HTML tag works.
  • 3.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 09:19 AM
    Can you elaborate a little? I have centered the title, header and footer and know how to use the center html tag, but I cannot find where to actually use the tag to center the form itself that is in the body. Thanks.
  • 4.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 09:32 AM
    Try adding the center tag at the top of the header on the registration page.
  • 5.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 09:35 AM
    Which skin are you using?
  • 6.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 11:12 AM
    Attempting to use custom skin 1. Adding the center tag in the header does not center the actual form with the fields the guest fills out. I have the headers, titles, footers and logo centered, just need to center the form itself. Thanks.
  • 7.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 11:44 AM
    It centres the form on my CPPM lab when adding the <center> tag at the top of the header as mentioned. I'm also using the custom 1 skin.
    Not sure why it's not doing it for you.
    Where does the form reside on your page? Alligned to the left?
    Have you added any customisation to the custom skin CSS?
  • 8.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 11:51 AM
    Take a look. Feel free to screen shot your setup in your lab so I can see what you are talking about. Thanks.
  • 9.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 11:56 AM
    Add <center> in the Header HTML section at the top.
    FYI You may also need to close the <center> tag you've got in the title.
  • 10.  RE: Custom Skin Help - Clearpass Guest Self Registration
    Posted Jan 23, 2017 11:58 AM
    Thank you, that did it.
