Network Management
custom syslog alarm
  • 1.  custom syslog alarm
    Posted Nov 09, 2015 09:34 AM
    I am new to IMC (7.1) and i'm attempting to setup an alarm for failed power supplies on HP switches.    Per this link (http://www.netopscommunity.net/forums/-/message_boards/message/114533)  I setup a syslog alarm but it is not working.   My syslog entries look like this:
    	<12> Nov  6 15:44:46 10.100.30.2 00071 chassis:  ST1-CMDR: Power Supply failure: Supply: 2, Failures: 4
    And here is my current alarm settings:
    	Syslog Type	Any
    	Syslog Level	Emergency Alert Critical Error Warning Notification Informational Debugging
    	Repeat Interval (second)	1
    	Repeat Times (Times)	1
    	Alarm Level	Critical
    	Alarm Description	%Syslog%
    	Forward to SCC	No
    	Syslog Template	*chassis:* Power Supply failure*
           Param Setting     Total Items: 0.
    I have restarted the imcfaultdm service on the service to recache the alarms (I found this information online somehwere).  Yet when I simulated a failure it does not generate a alarm.   Any advice?
    Aaron
  • 2.  RE: custom syslog alarm
    Posted Mar 27, 2024 09:17 AM
    i would like to do the same, do you have a working solution?
    kind regards,
    Martin
