Network Management
Customize AMP Web UI
  • 1.  Customize AMP Web UI
    Posted Jul 31, 2018 02:27 PM
    AMP Web UI login page: Currently there's this little window in the center with the motd which doesn't quite fit, and the login fields usually covered over by the copyright and footer.  I'd like to make the login-dialog and motd and login-containers wider (currently it appears to be hardcoded to 360x480) and percentage based rather than hard-coded.
    I'd like to customize these - where are the source css files for these items? Or can we have the ability to resize added to the gui.   Thanks
    See login snippet for example:login_snippet.JPG
  • 2.  RE: Customize AMP Web UI
    Posted Jul 31, 2018 04:21 PM
    You are correct that the template is hardcoded.  Please open a support case to have this filed as a defect.
