It's possible to modify the header with HTML code but how about using variables to display different code. I explain, I would like to add a banner that change according to a variable (IP of the WLAN for example).
Can I do this ? Perhaps with JavaScript ? Or something else ?
Thanks.
Dimitri
Yes you can.
I suggest you looking up the Reference part of "ClearPass Guest Deployment Guide 6.0.2.pdf".
One tip is to use this command in the footer to list all parameters available for you.
{dump var=$params export=html}
