Customize login page of Guest network
  • 1.  Customize login page of Guest network
    Posted May 04, 2016 01:56 AM
    Is it possible to customize the default login page for Guest network?
    I'm not able to see this option in my AP(Upload this file in "Management > Captive Portal > Upload Login Pages" as mentioned in http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/Internal-Captive-Portal-with-automatic-guest-auth-and-redirect/td-p/131299
    AP: Aruba IAP 225
  • 2.  RE: Customize login page of Guest network
    Posted May 04, 2016 04:22 AM
    Those instructions that you linked are for a controller-based AP.  You cannot customize the internal captive portal of an IAP.  You would have to point to an external web page to customize the Captive Portal HTML.
