Customize Secure Portal Vs. Guest Portal
  • 1.  Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 11:38 AM
    We had a consultant install a couple Aruba controllers and a Clearpass appliance.  Everything is working well so far.  We have a network that guests can attach to that produces a captive portal page.  However, the captive portal elements don't align with the portal editor section in Administration>Agents and Portals>Guest portal.
    The portal that appears seems to be located at https://securelogin.arubanetworks.com/cgi-bin.......etc.
    How can I edit that page to put our school logo and link to our acceptible use policy?
    Thank you in advance,
    -Ian
  • 2.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 01:21 PM
    Most likely your guest page is not hosted at Administration>Agents and Portals>Guest portal.  It is being deprecated.
    Please download the ArubaOS 6.1 userguide and look at Chapter 15, under "Customizing the Captive Portal".
  • 3.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 01:25 PM
    Thank you for the feedback.  We're running code 5.2 on the CPPM.  I'll check out that documentation.
    -Ian
  • 4.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 01:26 PM
    What WLAN platform are you running?
  • 5.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 01:40 PM
    We have a couple of Aruba 3600 controllers in a Master-Local setup.  I'm not sure if that's what you're asking me for though.  I'm still really new to this environment.
    Thanks again.
  • 6.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 01:42 PM
    Just making sure you had Aruba for your WLAN.
    You might be able to find your Captive Portal Configurationon the Aruba controller under Configuration> Management> Captive Portal
  • 7.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 01:49 PM
    I did see that, but any change I make doesn't seem to reflect what users see.  I'll probably have to open up a support ticket.  Thanks for the assistance.
  • 8.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 04:40 PM
    Are you trying to use the Captive Portal page on the controller or CPPM?   It sounds like you are trying to get them to use the CPPM one; but what is they are seeing?   Check the URL defined for the Login Page in the captive portal authentication profile on the controller for this user.
    Configuration --> Authentication --> L3 Authentication --> Captive Portal Authentication Profile --> Your Profile Name
    Login Page = ????????    Does it say /auth/index.html or does it point to your CPPM box?
  • 9.  RE: Customize Secure Portal Vs. Guest Portal
    Posted Dec 03, 2012 01:51 PM
    See if you can change the profile drop down to something besides default.
