Customized Captive Portal
  • 1.  Customized Captive Portal
    Posted Feb 17, 2014 06:05 PM
    Hi, is possible add field in Guest Self Registration = Date
    attachments image
  • 2.  RE: Customized Captive Portal
    Posted Feb 17, 2014 06:19 PM
    My question would be what would it be used for. The date is already tagged on the account when they register.
  • 3.  RE: Customized Captive Portal
    Posted Feb 17, 2014 06:25 PM
    Sorry for not explaining well,
    I need to ask for birthday
  • 4.  RE: Customized Captive Portal
    Posted Feb 17, 2014 06:27 PM
    Yes you can but at the moment I'm not by a computer. I can put together a how - to later tonight.
  • 5.  RE: Customized Captive Portal
    Posted Feb 17, 2014 06:29 PM
    Thanks Arnold,
  • 6.  RE: Customized Captive Portal
    Posted Feb 17, 2014 10:10 PM
    Couple Notes. The first link is based on the old amigopod system but it is all the same except the reports. The second link includes on how to do reports. I aslo attached a PDF based on the second link.
    http://www.amigopod.com/HOWTO/Survey/
    If you have partner access.
    https://afp.arubanetworks.com/afp/index.php/How-To:_Create_a_Self_Registration_Survey
  • 7.  RE: Customized Captive Portal
    Posted Feb 17, 2014 10:28 PM
    Thanks very much!!!
