Customizing SMS
  • 1.  Customizing SMS
    Posted Feb 18, 2013 09:45 AM
    Is it possible to customize the text of the received SMS ? For example, changing Visitor Access or Powered by Aruba.
    Boxcar
  • 2.  RE: Customizing SMS
    Posted Feb 18, 2013 10:26 AM
    Sure,
    Customization --> Print Templates --> Guest Manager Print Templates --> SMS Receipt
    and you can use all that variables
    Variable Description Example
    {$u.username}User account name12345678
    {$u.password}User account password87654321
    {$u.enabled}Non-zero if the guest account is enabled1
    {$u.role_name}Role assigned to guest accountGuest
    {$u.schedule_time}Time at which the guest account will become active1155772123
    {$u.expire_time}Time at which the guest account will expire1155858523
    {$u.expire_postlogin}Lifetime of the guest account login in minutes after login120
    {$u.visitor_name}User’s nameSusan Guest
    {$u.visitor_company}User’s company nameAcme Sprockets
    {$u.sponsor_name}Sponsor’s nameJohn Sponsor
    {$u.custom_field}Custom fields attached to the account
    {$action}Action taken on account (create, delete or edit)create
    {$source}Source of account action (create_user, reset_password, etc.)create_user
    {$result.error}Non-zero if an error occurred while creating the guest account0
    {$result.message}Message related to the account creation
    {$timestamp}Time at which the receipt was generated1155752000
    {$site_ssid}SSID of the wireless LANAruba
    {$site_wpa_key}WPA key for the wireless LAN
  • 3.  RE: Customizing SMS
    Posted Feb 18, 2013 10:27 AM
    As far as I know, you can edit the sms receipt under the configuration ==> print templates ==> sms receipt
  • 4.  RE: Customizing SMS
    Posted Feb 18, 2013 10:28 AM
    Thanks, I haven't check there.
    Boxcar
