Cloud Managed Networks
CX 6300 in Central?
  • 1.  CX 6300 in Central?
    Posted May 04, 2020 02:12 PM
    Am I missing something?  It appears that the CX 6300 is not supported in Central?  Are they working this?  If so, when will it be ready?
  • 2.  RE: CX 6300 in Central?
    Posted May 04, 2020 02:17 PM
    Yes CX switches will be supported in Central soon..
  • 3.  RE: CX 6300 in Central?
    Posted May 04, 2020 03:26 PM
    Ayman,
    Thanks for the reply.  Any idea on a time-frame?  I have an upcoming deployment that is well suited for the CX 6300, but not if it's not supported by Central.
  • 4.  RE: CX 6300 in Central?
    Posted May 05, 2020 12:59 PM
    I would recommend you check with your local Aruba SE for updates..
  • 5.  RE: CX 6300 in Central?
    Posted May 05, 2020 02:27 PM
    For those interested in this topic, here is the answer from my local rep relative to CX support in Central.
    Current road map timing:
    Central 2.5.2 in July – will support template groups only
    Central 2.5.3 in Oct-Nov will support GUI phase 1 ( no routing)
