Cloud Managed Networks
CX Device Profiles with Central
  • 1.  CX Device Profiles with Central
    Posted Jun 11, 2024 10:00 AM
    Looking to implement dynamic VLAN assignment via Central for some CX 6300 switches.  Are we able to implement this within Central via UI or does this need to be done by Template Group?
  • 2.  RE: CX Device Profiles with Central
    Posted Jun 11, 2024 10:22 AM
    Yes. You can set up the RADIUS authentication for the ports via the UI group. If you need more granular control via CLI, you can use multi-edit to configure the switches. The RADIUS server can then send back Roles and/or VLANs as part of the RADIUS response.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
