yes that seems to be the case. I think you should be able to download the firmware from Central and then manually start the ISSU upgrade.
Original Message:
Sent: Aug 07, 2024 11:42 AM
Subject: CX VSF ISSU and Aruba Central
Does anyone know if an upgrade of a 6300 stack from Aruba Central leverages hitless VSF In-Service Software Upgrade?
From what is available in the Central GUI I suspect this is not supported, I'm curious if there are any workarounds or kludges to take advantage of ISSU via Central.
