Network Management
CX6000 Switch Series - BPDU has wrong Protocol ID and version
This thread has been viewed 35 times
  • 1.  CX6000 Switch Series - BPDU has wrong Protocol ID and version
    Posted Mar 02, 2022 06:08 PM
    Hello there,
    yesterday I have successfully installed my first CX6000 series switch, which absolutely works like a charm.
    Everything works fine, but I got the following warning message every 2 seconds in the switches log, which I cannot explain.
    Event|2004|LOG_WARN|AMM|1/1|BPDU has wrong Protocol ID and version from port 49
    Port 49 is the switches uplink to another site and it is connected to a stack of 5406Rzl2 switches. Both the CX6000 and the 5406 zl2 are configured to do mstp and both are running on an actual firmware.
    Has anybody an idea how to fix this? Other switches, mostly Aruba 2530 and HP 1820 don't bother on the BPDU protocol versions...
    Best regards
    Alex
    Alex Lüttgen
  • 2.  RE: CX6000 Switch Series - BPDU has wrong Protocol ID and version
    Posted Jun 26, 2024 03:39 AM
    I had the same issue, due to mismatching vlan config on ports.
    5406Rzl2 port needs to have the same vlans then the port on CX6000.
  • 3.  RE: CX6000 Switch Series - BPDU has wrong Protocol ID and version
    Posted Jun 27, 2024 04:36 AM
    Thanks man! Finally after two years the warning every two seconds is solved!
