Wired Intelligent Edge
D Series SFP Compatibility
  • 1.  D Series SFP Compatibility
    Posted Feb 21, 2018 05:28 AM
    Hi All, i have a question about the new 'revision D' SFP's and their compatibility. So i understand that the C series are pre-EoL and they are to be replaced by revision D but i wanted to check that if I replace a switch and use the new rev D SFP (example J4858D) and the far end of the fibre connection is a rev C (J4858C) that there is no incompatibility issue there? I know it states on the EoL announcement that rev D are 'Backwards Compatoble' but it doesnt go into any detail about what this means.
  • 2.  RE: D Series SFP Compatibility
    Posted Feb 22, 2018 11:52 AM
    You are good to go. Rev D are essentially currently shipping versions.
    We made the change to eliminate the possibility of using older versions of the Rev A, B, C parts on our newer switch families
  • 3.  RE: D Series SFP Compatibility
    Posted Jul 23, 2020 12:24 PM
    Hello ED
    In a follow up J4858c is upgrade to J4858d?
    do they work the same?
    thanks
  • 4.  RE: D Series SFP Compatibility
    MVP GURU
    Posted Jul 24, 2020 12:13 PM
    @greco wrote: In a follow up J4858c is upgrade to J4858d? do they work the same?
    Where both revisions are supported, Yes they do.
    For reference have a good read about "Revision D" on the HPE Aruba ArubaOS-Switch and ArubaOS-CX Transceiver Guide (Edition Part Number 5200-3362 (Published May 2020).
  • 5.  RE: D Series SFP Compatibility
    Posted Jul 24, 2020 01:39 PM
    I realize that i didn't really address the original point (Roblowe14
    two different implied questions:
    a) will the newer Revisions work in an older switch
    b) will the newer Revisions connect to the older xcvr on the other end
    YES, the technology of a Rev C or Rev D (or even Rev E) are the same.
    The newer Rev Xcvr will optically connect to an older xcvr of the same type;   J4858C over fiber will work with a J4858D.
    Thanks Davide for watching out for this topic.
  • 6.  RE: D Series SFP Compatibility
    Posted Jul 24, 2020 01:48 PM
    thank you
  • 7.  RE: D Series SFP Compatibility
    thank you ED
  • 8.  RE: D Series SFP Compatibility
    MVP GURU
    Posted Jul 24, 2020 03:26 PM
    Ed, you're the best. Will came the time I'll listen your bass live? who knows...
  • 9.  RE: D Series SFP Compatibility
    Posted Jul 24, 2020 01:47 PM
    thank You very much for your reply..
