last person joined: 10 hours ago
dACL with object group
  • 1.  dACL with object group
    Posted Apr 12, 2020 07:28 AM
    Hi
    is there any way to use object group in the dACL ?
    when i'm trying to create dACL with object group it's applied to the interface as permit ip any any
    this is the dACL on CLearpass :
    Spoiler
    permit ip any object-group CCTV-Local-System
    and this is what applied on cisco switch
    Spoiler
    permit ip any any
    any solution ?
  • 2.  RE: dACL with object group
    Posted Apr 12, 2020 12:32 PM
    Hi
    Is the configuration working without the object-group option?
    The experience I had with dACL on cisco is that if the ACL is misconfigured on clearpass it will not be applied to the port.
    During the tests I used a default acl applied to all access ports and created dACLs on clearpass based on the access permission given to user's session.
    ip access-list extended default_acl
     permit ip any any
    interface range f0/1-24
     switchport mode access
     ip access-group default_acl in
     authentication host-mode multi-auth
     authentication order dot1x mab
     authentication priority dot1x mab
     authentication port-control auto
     authentication periodic
     authentication timer reauthenticate server
     mab
     dot1x pae authenticator
     dot1x timeout server-timeout 30
     dot1x timeout tx-period 10
     dot1x max-req 3
     dot1x max-reauth-req 10
    Please see attached file as an example of the ACL created on Clearpass.
  • 3.  RE: dACL with object group
    Posted Apr 12, 2020 01:14 PM
    thanks for your replay,
    I already configure more than one row in the dACL and all of them works correctly except the one that have object group.
    let me explain to you;
    if I configured dACL on Clearpass Like the below:
    permit ip any host 1.1.1.1
    permit ip any host 2.2.2.2
    permit icmp any host 3.3.3.3
    deny ip any any log
    what  will be applied on Cisco Switch like this :
    permit ip any any
    deny ip any any log
    it must install
    permit ip any object-group CCTV-Local-System  instead of  permit ip any any.
  • 4.  RE: dACL with object group
    Posted Apr 13, 2020 06:58 AM
    I understand the problem now. So the switch is replacing the object-group with an "any".
    That could be related to the configuration of the object-group. There are some options to use it but the configuration for the object-group  may be different depending on how you are going to use it on your ACL statement. For example,  you can replace the source, destination or protocol/ports on your ACL statement with an previous configured object-group, but for each option you may apply a different configuration to create the object-group
    Can post here the confirmation of your object-group?
  • 5.  RE: dACL with object group
    Posted Apr 13, 2020 08:12 AM
    Hi
    this is the object group that we have configured on the switch
    object-group network CCTV-Local-System
    10.30.30.0 255.255.255.240
