Daily License reports
  • 1.  Daily License reports
    Posted Jun 16, 2014 11:04 AM
    I have a customer with around 25 controllers. When running the Airwave Daily Licensing report, only 4 controllers are reported.
    I have checked the snmp strings and the mgmt-server settings but I still can't see more than those 4.
    Any suggestions?
    Does the reporting agent poll the controllers when the report is run or do I have to manually poll after a configuration is changed?
  • 2.  RE: Daily License reports
    Posted Jun 17, 2014 07:55 PM
    To find out if it is the credentials or the report, SSH into Airwave and use the "on_controllers" command to show licenses on all controllers:
    on_controllers "show license"
     It will tell you if it fails on any controllers and why.
  • 3.  RE: Daily License reports
    Posted Jun 18, 2014 01:58 PM
    Thanks Colin,
    All the devices showed up in the command line which led me back to the report.   I opened the restrictions up on the report to  all groups, all folders, and all device types. Capacity threshold is at 0 and I'm still only receiving 4 controller outputs. Is there anything else I could be missing?
    I did notice that on the device info screen for the devices that are reporting their licenses; there is actually a link where I can look at the licenses from that page. The other controllers do not have the link:license button.jpg
