Hi! AFAIK the HPE OfficeConnect 1420 Switch Series represents only unmanaged Switches...so there is no way to configure them for a particular purpose other than being plug&play Layer 2 switches.
Technically you shouldn't need a crossover patch cable between them because they support Auto-MDIX...so it can't be an issue related to their physical interconnection.
Given that you can daisy-chain them simply by connecting any port on the first 1420 switch to any port on the second 1420 switch the only question that come to mind is: what is the state of the ports used for daisy chaining them (Link/Activity)?
