Dashboard clients per SSID graph not working since 7.7.9 upgrade
  • 1.  Dashboard clients per SSID graph not working since 7.7.9 upgrade
    Posted Feb 27, 2014 03:35 AM
    Hi there,
    Since I've upgraded to 6.31.2 and Aiwave 7.7.9 I seem to have lost visibility of numbers of clients on the Airwave home screen dashboard. I'm guessing I should log a TAC case, but thought i'd check in here first to see if it was a known issue.
    I've attached two screenshots which illustrate this. Note the over-last-day graph indicating that the max clients are attached to 'unknown'.
  • 2.  RE: Dashboard clients per SSID graph not working since 7.7.9 upgrade
    Posted Feb 27, 2014 04:02 AM
    A TAC case would be the best thing.  I don't see it here on my version..
  • 3.  RE: Dashboard clients per SSID graph not working since 7.7.9 upgrade
    Posted Feb 27, 2014 08:50 AM
    ok will do, thanks for speedy response!
  • 4.  RE: Dashboard clients per SSID graph not working since 7.7.9 upgrade
    Posted Mar 04, 2014 07:43 AM
    A quick update on this (FYI),
    TAC suggested that there is an issue with AMON polling which was preventing these stats. *prefer* AMON has been switched to "no" in Airwave's AMP Setup menu, and this has successfully worked around the isseu.
