Dashboard doesn't display client, IP, or role
  • 1.  Dashboard doesn't display client, IP, or role
    Posted Jul 01, 2014 04:42 PM
    On a controller servicing only RAPs, I am unable to see the client, IP, or role when looking at the Clients dashboard.  All I see is a "--" entry in those columns.  If I go to the monitoring tab > clients, I'm able to see all of this information.  Any thoughts?
  • 2.  RE: Dashboard doesn't display client, IP, or role
    Posted Jul 01, 2014 05:22 PM
    What version of ArubaOS?
  • 3.  RE: Dashboard doesn't display client, IP, or role
    Posted Jul 01, 2014 05:30 PM
    6.3.1.4
  • 4.  RE: Dashboard doesn't display client, IP, or role
    Posted Jul 01, 2014 06:40 PM
    Type "show keys" to see if you see the remote AP license on that controller
  • 5.  RE: Dashboard doesn't display client, IP, or role
    Posted Jul 02, 2014 11:08 AM
    Yes, remote APs are enabled.
  • 6.  RE: Dashboard doesn't display client, IP, or role
    Posted Jul 02, 2014 02:28 PM
    Please open a case.  I thought it was another bug involving licenses, but it appears to be a display bug.  Do you have campus APs on that same version with the same issue?
  • 7.  RE: Dashboard doesn't display client, IP, or role
    Posted Jul 02, 2014 02:32 PM
    I dont' have any controllers running the same version, unfortunately.  Of the other versions I'm running, I am not seeing this issue with CAPs.
  • 8.  RE: Dashboard doesn't display client, IP, or role
    Posted Jul 02, 2014 02:35 PM
    In case it matters, the version is 6.3.1.2 - whoops!  Still logging a ticket..
