Dashboard information delay between VMM and MC Cluster (8.5.0.2)
  • 1.  Dashboard information delay between VMM and MC Cluster (8.5.0.2)
    Posted Sep 27, 2019 12:51 PM
    Hi!
    I have an scenneario with 2 virtual Mobility Master (8.2.0.5) al ready configured with VRRP and Database syncronization  and 2 Mobility Controllers 7205 in a L2 cluster connected to the Virtual IP of the MM VRRP. (everything is in the same L2 subnet)
    We are having an issue using the MM WebGUI, is not showing the exact quantity of connected clients and AP and when browsing the dashboard looking for connected clientes is not showing name and other data, just the IP and MAC-address.  But if we go to the MC WebGUI you can see the correct info and the exact amount.
    Do you now if there is an issue using the Dashboard of the MM or there is a special configuration i'm missing?
    greetings
  • 2.  RE: Dashboard information delay between VMM and MC Cluster (8.5.0.2)
    Posted Sep 28, 2019 03:30 AM
    If you haven't, please open a case with TAC in parallel to this post.
  • 3.  RE: Dashboard information delay between VMM and MC Cluster (8.5.0.2)
    Posted Sep 30, 2019 06:39 PM
    thank you! I'm going to do it tommorrow :) but I guess nobody is having this issue :(
  • 4.  RE: Dashboard information delay between VMM and MC Cluster (8.5.0.2)
    Posted Nov 18, 2019 10:39 AM
    Hello! if someone else is having this issue it was resolved in ArubaOS 8.5.0.3
