In security stand point it is necessary?
I ask this because i see that we can add rules on the clearpass from where i can access the managment of clearpass, on the same clearpass.
we will use clearpass as radius server tacacs server and also as clearpass Guest.
The guest users will only have access only to the clearpass through the ports needed for that.
i would like to keep it simple and just use one port but im not sure if the data port was done also for security purpuses or was for something else in mind?
Cheers
Carlos
