  • 1.  Data rate
    Posted Nov 07, 2017 10:22 PM
    Hi Sir,
        I found  an AP  that uses 12Mbps-54Mbps transmission at most of the time?What factors can affect the data transfer rate?
  • 2.  RE: Data rate
    Posted Nov 08, 2017 02:43 AM
    It is entirely possible that those clients are not doing anything and are just sending management traffic back and forth.
    It is also possible that those clients are just 802.11a or 802.11g clients, and that would be perfectly normal.
    Lastly, the rate of frames is negotiated between the client and the access point.  If frames are not successful either because of distance or retries, the access point and/or the client could attempt to send the frames at a lower rate, which is typically more reliable.
