Hello everyone
I have medium network consist of one HP 5500 Series Core switch connected to 13 procurve 2910, and I have VOICE vlan 20 (172.17.0.1) and DATA vlan 30 (172.19.0.1) , the voice vlan connected to AVAYA CM ,, the CM has DHCP server
and it works fine
Port assingment:
For Voice:
vlan 20
name voice
tagged 1-43
voice
no ip addess (because ip given from Core switch )
For DATA
vlan 30
name data
untagged 1-43
no ip address
I ping the data vlan default gateway and have reachability from evey edge switch via consol cable with no problem
My problem:
when I connect the phone ,, its takes IP for AVAYA DHCP and works fine ,, BUT when connect from the phone to the PC i do not have reachability to the Data vlan... I wanna test the data vlan without DHCP by giving manual IP to my PC ,, how I Can make it work ??
I want be able to ping the default gateway of the Data VLAN from the PC ..
Kindly advice
thanks
P.S. This thread has been moved from ProCurve / ProVision-Based to Comware-Based. - Hp Forum Moderator
#VoiceVlan#datavlan#VLAN#ProCurve
