last person joined: 8 hours ago
Datapath failure caused controller reboot
  • 1.  Datapath failure caused controller reboot
    Posted Sep 26, 2012 03:31 PM
    I had a controller reboot a couple days ago and the reason in the logs was a datapath failure.  Has anyone seen or heard of this before?  I have a case open but wanted to get any input from the group.
  • 2.  RE: Datapath failure caused controller reboot
    Posted Sep 26, 2012 04:48 PM
    You need to contact support ASAP.
  • 3.  RE: Datapath failure caused controller reboot
    Posted Sep 26, 2012 07:25 PM
    can I ask what version it was and the controller please?
  • 4.  RE: Datapath failure caused controller reboot
    Posted Sep 28, 2012 11:17 AM
    I'm running 5.0.4.0.  Support suggested upgrading to 5.0.4.6 or 5.0.4.9.  I don't see that happening in the near furture.  I'm at a large healthcare facility so getting downtime is difficult to say the least.
    I guess I'll need to stay on 5.0.4.0 until it really becomes an issue.  Controller has been stable and has only booted once.
  • 5.  RE: Datapath failure caused controller reboot
    Posted Oct 02, 2012 12:58 PM
    We've had this issue before and only an upgrade has fixed it.
    I would suggest getting the process going to get the controller or controllers upgraded. If it takes a while at least the wheels are turning.
