Datapath session flag
  • 1.  Datapath session flag
    Posted Jul 29, 2014 05:58 AM
    I posted a while back looking for clarification on the significance and usage of the "Y" flag (No SYN) in the datapath session output. As I do remote support for customers this is sometimes the only proof that something is or is not working. This time round my question is when I ping a connected client on a RAP I get the Y flag against the outbound echo request but not against the echo response entries. If I do the same thing on a CAP I get the reverse - the Y flag is against the echo responses. If I ping a bogus IP address I get no Y flag at all. Whats going on here - can anyone enlighten me?
  • 2.  RE: Datapath session flag
    Posted Jul 30, 2014 01:46 AM
    Hi
    Can you add some examples to clarify each of your questions ? Pinging from where - controller CLI or attached trusted wired device ? What RAP mode ? are you only checking the controller dp session table, what about for RAP if split/bridge are you also checking the on-ap session table.
    From controller CLI (6.3.1.8) to CAP wifi client, I get no Y flags for responding pings, for unknown host (as long as there is route-cache to get out), I get Y flags as expected. The RAP case may be different, but need to know what you tested.
    regards
    -jeff
  • 3.  RE: Datapath session flag
    Posted Jul 30, 2014 03:35 PM
    The pings are being run from the controller CLI primarily but the same is happening from other devices on the network. The clients are on bridge mode SSIDs.
    The output I am looking at is from - show datapath session ap-name <apname>
  • 4.  RE: Datapath session flag
    Posted Jul 31, 2014 11:35 AM
    can you show example output and note the version you are using ? bridge rap or cpsec cap ?
    in my lab 6.4.x bridge cpsec cap not showing any flags for reachable icmp, unreachable tcp from ap side dp session table - there may be something buggy in here wrt flags it seems
    >> ex ping and ssh from cap bridge client to unreachable IP
    (sg-3200) #show datapath session ap-name ap105-24:78  | include 22,Flag
    Source IP       Destination IP  Prot SPort DPort Cntr  Prio ToS Age Destination TAge Packets   Bytes     Flags
    1.2.3.4         172.16.1.25     6    22    53509 0     0    0   0   dev15       20   0         0
    1.2.3.4         172.16.1.25     1    2     0     0     0    0   0   dev15       8    0         0
    1.2.3.4         172.16.1.25     1    1     0     0     0    0   0   dev15       20   0         0
    172.16.1.25 1.2.3.4 6 53509 22 0 0 0 0 dev15 20 0 0
    172.16.1.25     1.2.3.4         1    2     2048  0     0    0   0   dev15       8    0         0
    172.16.1.25     1.2.3.4         1    1     2048  0     0    0   0   dev15       20   0         0
    >> ping from CLI to reachable bridge cap client
    (sg-3200) #ping 172.16.1.25
    Press 'q' to abort.
    Sending 5, 92-byte ICMP Echos to 172.16.1.25, timeout is 2 seconds:
    Success rate is 100 percent (5/5), round-trip min/avg/max = 4.411/7.658/20.38 ms
    (sg-3200) #show datapath session table | include 172.16.1.25,Flag
    172.16.1.154    172.16.1.25     1    11    2048   0/0  0    0   0   local       1    1         120       FCI
    172.16.1.154    172.16.1.25     1    13    2048   0/0  0    0   0   local       1    1         120       FCI
    172.16.1.154    172.16.1.25     1    12    2048   0/0  0    0   0   local       1    1         120       FCI
    172.16.1.154    172.16.1.25     1    15    2048   0/0  0    0   0   local       1    1         120       FCI
    172.16.1.154    172.16.1.25     1    14    2048   0/0  0    0   0   local       1    1         120       FCI
    172.16.1.25     172.16.1.154    1    11    0      0/0  0    0   0   local       1    1         120       FI
    172.16.1.25     172.16.1.154    1    15    0      0/0  0    0   0   local       1    1         120       FI
    172.16.1.25     172.16.1.154    1    14    0      0/0  0    0   0   local       1    1         120       FI
    172.16.1.25     172.16.1.154    1    13    0      0/0  0    0   0   local       1    1         120       FI
    172.16.1.25     172.16.1.154    1    12    0      0/0  0    0   0   local       1    1         120       FI
    172.16.1.25     172.16.1.154    1    11    0     0     0    0   1   dev3        45   0         0
    172.16.1.25     172.16.1.154    1    15    0     0     0    0   1   dev3        45   0         0
    172.16.1.25     172.16.1.154    1    14    0     0     0    0   1   dev3        45   0         0
    172.16.1.25     172.16.1.154    1    13    0     0     0    0   1   dev3        45   0         0
    172.16.1.25     172.16.1.154    1    12    0     0     0    0   1   dev3        45   0         0
    172.16.1.154    172.16.1.25     1    11    2048  0     0    0   1   dev3        45   0         0
    172.16.1.154    172.16.1.25     1    13    2048  0     0    0   1   dev3        45   0         0
    172.16.1.154    172.16.1.25     1    12    2048  0     0    0   1   dev3        45   0         0
    172.16.1.154    172.16.1.25     1    15    2048  0     0    0   1   dev3        45   0         0
    172.16.1.154    172.16.1.25     1    14    2048  0     0    0   1   dev3        45   0         0
    rap bridge behaving the same as above.
  • 5.  RE: Datapath session flag
    Posted Aug 12, 2014 02:53 AM
    Attached is a screenshot with the pings traffic boxed. The lower 5 are the ping requests and the upper ones are the ping responses. So there are Y flags on the echo requests.
  • 6.  RE: Datapath session flag
    Posted Aug 12, 2014 02:57 AM
    strange, perhaps you have something enabled in firewall that is non standard, I am out of suggestions, next stop TAC case, sorry.
  • 7.  RE: Datapath session flag
    Sorry, forgot to add this is with version 6.1.3.5, the device is a RAP and the client is connected to a bridged SSID. Attached is a table showing the differences when running different commands and running pings to/from different devices.
  • 8.  RE: Datapath session flag
    Posted Aug 12, 2014 03:13 AM
    i'll try a quick test in 6.1.3.5 for you tomorrow and let you know if i see the same, for sure 6.4 doesnt appear to behave this way.
  • 9.  RE: Datapath session flag
    Posted Aug 13, 2014 05:14 AM
    MattF
    Looks like 6.4 is the odd man out, where someone has potentially hidden the flags. will ask R&D about it, 6.1.3.x and 6.3.1.x behave the same as your observations for AP side datapath session table. So far, I dont find any issue with the controller side flags using any of same samples in this post. I will raise a bug to try and ascertain:
    a> why the dp session table flags on AP are missing in 6.4.x
    b> why they are not correct in 6.3.x and lower (and whether a> is the 'solution' to that)
    regards
    -jeff
  • 10.  RE: Datapath session flag
    Posted Aug 13, 2014 05:16 AM
    Thanks, I appreciate your efforts.
  • 11.  RE: Datapath session flag
    Posted Aug 25, 2014 02:42 AM
    any update on this jgoff?
  • 12.  RE: Datapath session flag
    Posted Aug 25, 2014 02:45 AM
    hello boneyard
    The missing flags is a bug, it has already been fixed in the R&D stream and needs to be backpropped. The value of the flags is another matter, the dev working the bug is yet to respond to that.
    regards
    -jeff
  • 13.  RE: Datapath session flag
    Posted Aug 25, 2014 10:20 AM
    ok, thanks for the info.
