Datapath tunnels
  • 1.  Datapath tunnels
    Posted Jun 23, 2015 05:54 AM
    If I run the "show datapath tunnel table command" there are a number of different numbers in the type column. What do each of these numbers mean?
  • 2.  RE: Datapath tunnels
    Posted Jun 23, 2015 06:31 AM
    GRE Tunnels per BSSID build from the controller to the AP
  • 3.  RE: Datapath tunnels
    Posted Jun 23, 2015 06:33 AM
    That much I know, but there is no documentation I can find find which explains what the numbers mean in the type column.
  • 4.  RE: Datapath tunnels
    Posted Jun 23, 2015 06:55 AM
    http://community.arubanetworks.com/t5/tkb/articleprintpage/tkb-id/ControllerBasedWLANs/article-id/188
    Below are the GRE Type IDs:
    1. VAP Tunnels – starting from 8200 & 8300
    2. Enet Tunnel – starting from 8100
    3. Enet0 Tunnel (LAN Bridging) – 8080
    4. Split Tunnel – 8000
    5. GRE Hearbeat Tunnel – 9000
  • 5.  RE: Datapath tunnels
    Posted Jun 23, 2015 07:38 AM
    Thanks, that is exactly what I was looking for.
  • 6.  RE: Datapath tunnels
    Posted Jun 23, 2015 08:22 AM
    Some additionl Tunnel IDs in case you see them:
    • 8000    -- shared split tunnel
    • 8080    -- 651/653 internal AP FW
    • 8180    -- Ethernet port 0
    • 8100    -- Ethernet port 1
    • 8101    -- Ethernet port 2
    • 8102    -- Ethernet port 3
    • 8103    -- Ethernet port 4
    • 82x0    -- BSSIDs on radio 0
    • 83x0    -- BSSIDs on radio 1
    • 9000    -- Base-tunnel for heartbeats/keepalives
    • IPSE    -- IPsec map
  • 7.  RE: Datapath tunnels
    Posted Jun 23, 2015 10:11 AM
    Thanks for the additional information.
  • 8.  RE: Datapath tunnels
    Posted Jun 04, 2020 11:56 AM
    Can someone explain where the MTU value is coming from in this table?
