Hey everyone,
I've got my NTP config in place but I probably need to do something to correct for DST as currently I am an hour off. I have set my timezone to EST by using:
clock timezone EST minus 4:00:00
Now I need to setup DST. As far as I can tell, I have to use this command:
clock summer-time <TMZ> repeating <starttime> <startdate> <endtime> <enddate> <timeoffset>
Where TMZ is the 3 letter/4 letter/ timezone indicator. Start time is in hh:mm:ss format and indicates the time in which DST begins. Start date is in mm/dd/yy format that marks the date in which it starts. Endtime is in hh:mm:ss and indicates the time in which DST ends. Enddate is in hh:mm:ss and indicates the date in which DST ends. Timeoffset is in hh:mm:ss and indicates the skew for DST.
My question is DST occurs on different dates each year. Does this command some how understand the floating time offset dates?
#NTP#DST
