Network Management
db on the heat map is anything bad?
  • 1.  db on the heat map is anything bad?
    Posted Nov 19, 2015 11:06 AM
    The heatmap shows some areas orange, some red and some green.   It looks like those represent 45-75db
  • 2.  RE: db on the heat map is anything bad?
    Posted Nov 19, 2015 11:27 AM
    Can you elaborate on what your question is?   I assume you are referring to VisualRF in AirWave.  The colors represent the dBm of the AP.    Red is -45, Orange is -55, Green is -65, Blue is -75, Purple is -85.
    Red is "very good/good" in this case.
  • 3.  RE: db on the heat map is anything bad?
    Posted Nov 19, 2015 11:31 AM
    Thanks - we are seeing red, orange and green - no purple.   Is green still acceptable?   Will they see diminished speeds or disconnectivity in the green zones?  (the red zone is for loading and unloading only - couldn't resist an airplane quote)
  • 4.  RE: db on the heat map is anything bad?
    Posted Nov 19, 2015 11:37 AM
    Typically when doing a predeployment survey, -65 is the target dBm (green in this case).  If your coverage has green, orange, and red, then you likely have a good coverage model.   Keep in mind whether you are looking at 2.4 GHz or 5 GHz frequencies when looking at this.  In a coverage model, you'll want this signal on 5 GHz as well as 2.4 GHz.
  • 5.  RE: db on the heat map is anything bad?
    Posted Nov 19, 2015 11:47 AM
    Is there anyway on the heatmap to show only the clients connected at 2.4 or just the 5GHz clients?
  • 6.  RE: db on the heat map is anything bad?
    Posted Nov 19, 2015 12:09 PM
    In AirWave, you cannot show only 5 GHz clients; when showing clients, it shows all.
  • 7.  RE: db on the heat map is anything bad?
    Posted Nov 19, 2015 12:18 PM
    Thanks - that would be a nice feature in the next version.
  • 8.  RE: db on the heat map is anything bad?
    Posted Nov 19, 2015 03:00 PM
    You can run reports to show only 2.4Ghz clients connected. You can also turn on client associations in VisualRF, blue links will be 2.4Ghz, green links will be 5Ghz.
