Dears help if you can in this issue?
  • 1.  Dears help if you can in this issue?
    Posted Jun 23, 2014 07:40 AM
    I have full redandt controller archticture
    2 masters 1 active 1 standby work very well
    1 local with trunk port allowed vlans needed and cant't ping the VRRP IP but can ping the master 1 and master 2 on the smae vlan
    and on the master I can ping the local
    so why I should do to solve this ?
    using trunk port and pass IPSEC makeing any issue?
    I'm using controller 3200XM os 6.4
  • 2.  RE: Dears help if you can in this issue?
    Posted Jun 23, 2014 08:09 AM
    Is your VRRP session up?
    Run:
    show vrrp
  • 3.  RE: Dears help if you can in this issue?
    Posted Jun 23, 2014 09:27 AM
    running very well I have strange issue I use access vlan 20 and on switch 2 ports vlan 20 1 for the master and 1 for the local
  • 4.  RE: Dears help if you can in this issue?
    Posted Jun 23, 2014 09:28 AM
    and master can ping local and local can't ping VRRP whcih it is running very well
