Dears what is the best configuration for VRRP between Master-Master Standby?
  • 1.  Dears what is the best configuration for VRRP between Master-Master Standby?
    Posted Jun 19, 2014 03:00 PM
    what is the best configuration Master-Standby Master and what is preemtion feature and how to make access point came back automatically to the first active Master controller after fail issue solved?
  • 2.  RE: Dears what is the best configuration for VRRP between Master-Master Standby?
    Posted Jun 19, 2014 03:12 PM
    Please read this document:
    http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_UG/VRRP.php
    The preemption option will allow the APs to come back to the main master but you have to be careful when enabling this because if your main controller is having issues coming up and down then you could create ping - pong effect with the APs going back and forth between controllers , add the following :
    tracking master-up-time 30 add 20
